Home > Technical (L405) > How do I open a deadlocked rear door? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
so its not the child lock on as you cant open from the outside..
16th Jul 2024 2:23pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 |
Stan, I hadn't thought of battery disconnection, if that works I will come to Swindon and erase the Magic Roundabout 2013 L405 Autobiography Baltic Blue
16th Jul 2024 3:03pm |
best roundabout in the world that is... ... - .- -.
16th Jul 2024 3:42pm |
It may well be but can it get my door open 2013 L405 Autobiography Baltic Blue
16th Jul 2024 5:10pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 |
I had this with my discovery 3 last year, the door would sometimes work but then stopped fully. I decided to try and tackle it one evening but because mine was a commercial I couldn't actually get the door car off. So what I did was cycle the lock unlock on the remote while also pulling the handle and locking and unlocking it manually at the door, after about 3 minutes I got lucky and the door popped.
17th Jul 2024 7:33am |
Have tried everything within reason and no further forward, tomorrow morning it is the reciprocating saw, wish me luck Hate to do it but cannot see another option ! 2013 L405 Autobiography Baltic Blue
18th Jul 2024 5:16pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 542 |
Hang on! Long shot and I know this might be completely different, but on the front door of an L322 (late model, don't know if others are the same), you can insert a long handled screwdriver down between the door glass and the door after removing the trim, you can then smash a hole in the top of the plastic cover on the door lock mechanism and with a bit of fiddling the deadlock releases. Drives:
19th Jul 2024 8:05am |
I have been procrastinating however got the reciprocating saw out today. cut the internal part of the door and managed to open it, now I need a new lock mechanism, happy days 2013 L405 Autobiography Baltic Blue
9th Aug 2024 5:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 |
That sounds like a horrible job, got any pictures of what you had to do...??? Pete
9th Aug 2024 10:00pm |
Will post some later today Pete, not for the fainthearted 2013 L405 Autobiography Baltic Blue
10th Aug 2024 4:40am |
So the screws that hold the lock mechanism are by the lock which you cannot get too when it is deadlocked. Removed internal door card (not difficult even when door is shut), then you have limited access to the actual lock. Couple of cuts to internal door with reciprocating saw (not easy) then bend back internal metal and smash existing locking mechanism until door opens, no damage to external door and once all parts are back in place you would never know I had been in there, (hopefully), I just need to make sure I order the correct part now
10th Aug 2024 1:35pm |
Good there is no damage on view afterwards, well done... Pete
10th Aug 2024 6:08pm |
Its been a pain Pete, however I cant see any other way of doing it, once you get over the thought of the saw, was fun..... 2013 L405 Autobiography Baltic Blue
10th Aug 2024 7:20pm |
Pete
10th Aug 2024 11:33pm |
