Home > Technical (L405) > How do I open a deadlocked rear door?
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
My rear drivers door is locked shut and wont open from inside or out, I have removed the door card and internal trim to gain access to wiring etc, unplugged all connections one at a time to try to isolate issue to no avail, how do I remove latch/actuator with door shut?
Any help appreciated, thanks Thumbs Up 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #696304 16th Jul 2024 12:55pm
so its not the child lock on as you cant open from the outside..
there has been an issue with soft close doors which an ecu update cures...some forum threads on this..
firstly i would try a battery disconnection.. Wink ... - .- -.
Post #696308 16th Jul 2024 2:23pm
Rosco
Stan, I hadn't thought of battery disconnection, if that works I will come to Swindon and erase the Magic Roundabout Rolling with laughter 2013 L405 Autobiography Baltic Blue
Post #696312 16th Jul 2024 3:03pm
best roundabout in the world that is... Laughing ... - .- -.
Post #696315 16th Jul 2024 3:42pm
Rosco
It may well be but can it get my door open Big Cry 2013 L405 Autobiography Baltic Blue
Post #696322 16th Jul 2024 5:10pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
I had this with my discovery 3 last year, the door would sometimes work but then stopped fully. I decided to try and tackle it one evening but because mine was a commercial I couldn't actually get the door car off. So what I did was cycle the lock unlock on the remote while also pulling the handle and locking and unlocking it manually at the door, after about 3 minutes I got lucky and the door popped.
Everyone I saw with this issue replaced the lock mechanism but for me this was not faulty, all that happened was that the white grease that was put on nearly 20 years ago dried up and just made the mechanism sticky. After I completely took it apart, cleaned it and re greased it the door has been fine.
Not sure will this work on the RR as the door lock is not within the handle but its worth a shot for the sake of the few minutes.
best of luck Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #696358 17th Jul 2024 7:33am
Rosco
Have tried everything within reason and no further forward, tomorrow morning it is the reciprocating saw, wish me luck Thumbs Up Hate to do it but cannot see another option ! 2013 L405 Autobiography Baltic Blue
Post #696454 18th Jul 2024 5:16pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Hang on! Long shot and I know this might be completely different, but on the front door of an L322 (late model, don't know if others are the same), you can insert a long handled screwdriver down between the door glass and the door after removing the trim, you can then smash a hole in the top of the plastic cover on the door lock mechanism and with a bit of fiddling the deadlock releases. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #696481 19th Jul 2024 8:05am
Rosco
I have been procrastinating however got the reciprocating saw out today. cut the internal part of the door and managed to open it, now I need a new lock mechanism, happy days Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #697729 9th Aug 2024 5:07pm
That sounds like a horrible job, got any pictures of what you had to do...??? Pete
Post #697757 9th Aug 2024 10:00pm
Rosco
Will post some later today Pete, not for the fainthearted Rolling with laughter 2013 L405 Autobiography Baltic Blue
Post #697764 10th Aug 2024 4:40am
Rosco
So the screws that hold the lock mechanism are by the lock which you cannot get too when it is deadlocked. Removed internal door card (not difficult even when door is shut), then you have limited access to the actual lock. Couple of cuts to internal door with reciprocating saw (not easy) then bend back internal metal and smash existing locking mechanism until door opens, no damage to external door and once all parts are back in place you would never know I had been in there, (hopefully), I just need to make sure I order the correct part now Rolling with laughter
Post #697779 10th Aug 2024 1:35pm
Good there is no damage on view afterwards, well done... Thumbs Up Pete
Post #697797 10th Aug 2024 6:08pm
Rosco
Its been a pain Pete, however I cant see any other way of doing it, once you get over the thought of the saw, was fun..... Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #697801 10th Aug 2024 7:20pm
Thumbs Up Bow down Thumbs Up Pete
Post #697805 10th Aug 2024 11:33pm
