Home > Maintenance & Mods (L322) > 3.6TDV8 Power Steering Pump Replacement |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
Well done !
8th Jul 2024 10:48pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 688 |
Got everything buttoned back up, power steering is improved but not quite how it should be.
18th Jul 2024 9:53pm |
Mine is normally quiet under all conditions except full lock - unless fluid level is low and presumably it's then pulling air through.
18th Jul 2024 10:49pm |
Thanks for the info Pawl,
19th Jul 2024 4:51pm |
Getting no where with this, stripped it down again today to check if the seals on the high pressure line our of the pump were leaking.
26th Jul 2024 10:09pm |
So I've replaced the pump again with another one.
2nd Aug 2024 5:32pm |
