![]() | Home > Maintenance & Mods (L322) > 3.6TDV8 Power Steering Pump Replacement |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
Well done !
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 735 ![]() ![]() |
Got everything buttoned back up, power steering is improved but not quite how it should be.
Mine is normally quiet under all conditions except full lock - unless fluid level is low and presumably it's then pulling air through.
Thanks for the info Pawl,
Getting no where with this, stripped it down again today to check if the seals on the high pressure line our of the pump were leaking.
So I've replaced the pump again with another one.
