Home > Technical (L405) > Transmission not smooth when cold |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Get the fluid level checked, get a dealer or Indy with dealer diagnostic kit to make sure you have the latest gearbox software. Reset the throttle by holding down the accelerator, Turing on the ignition and holding for 30 seconds then turn off the ignition and release the pedal. 2012 TDV8 Vogue (L322) |
17th Jul 2024 8:31am |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
Time for a pan and fluid change with a recalibration as a starting point. Also fresh fluids in the transfer case and two differentials. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
17th Jul 2024 2:08pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7966 |
I had similar with mine & it went away after a gearbox flush.
17th Jul 2024 3:52pm |
Silverstone Member Since: 30 May 2024 Location: Silverstone Posts: 24 |
UPDATE - picked the car up again yesterday after change of oil in gearbox and software update. All much smoother! "There is no replacement for displacement" - W O Bentley |
28th Jul 2024 11:27am |
28th Jul 2024 3:05pm |
