![]() | Home > Maintenance & Mods (L405) > Shake, rattle and roll - together with some creaking. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3889 ![]() ![]() ![]() |
My rear parcel shelf makes some or all of the above noises on rougher roads, if it take it out the noises go with it, so its definitely the shelf. Does anyone else have this problem and is there an easy fix, at present I have wedged the offending shelf but have not had chance to test. Geoff |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
Don't wish to teach you to suck eggs Geoff, but have you checked it has four, non broken, locating pins and it is clicked fully home..?? |
All pins intact and shelf locked in place OK. However I did discover On the way back from shopping was if the shelf was in position but half folded it makes less noise which leads me to suspect the rear pins Geoff |
Mine squeaked/rattled a bit, I played with the back rests in the rear and it shut up, I think it was catching the seat back or the flap that's there.... |
