Home > Maintenance & Mods (L405) > Shake, rattle and roll - together with some creaking.
supershuttle
My rear parcel shelf makes some or all of the above noises on rougher roads, if it take it out the noises go with it, so its definitely the shelf. Does anyone else have this problem and is there an easy fix, at present I have wedged the offending shelf but have not had chance to test. Geoff
Post #696233 15th Jul 2024 4:24pm
Don't wish to teach you to suck eggs Geoff, but have you checked it has four, non broken, locating pins and it is clicked fully home..?? Thumbs Up Pete
Post #696239 15th Jul 2024 4:59pm
supershuttle
All pins intact and shelf locked in place OK. However I did discover On the way back from shopping was if the shelf was in position but half folded it makes less noise which leads me to suspect the rear pins Geoff
Post #696253 15th Jul 2024 8:15pm
Mine squeaked/rattled a bit, I played with the back rests in the rear and it shut up, I think it was catching the seat back or the flap that's there.... Thumbs Up Pete
Post #696266 15th Jul 2024 10:41pm
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
Drives me mad!
I've found that if I make sure that it's centralised (left to right) with an equal gap on each side (approx 4mm) it does tend to stop the creaking. 2017 SDV8 Autobiography
Post #696283 16th Jul 2024 10:07am
