Home > General (L405) > SVO options
If you're going to use the main stealers then a service plan may well be worthwhile. If you're going tp use proper independent mechanics who can see what's needed even if the computer says "no", then there's little point. JM2pW Mike - MPx
Post #696029 11th Jul 2024 10:00pm
Nabbler
Wales 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Mike could I ask a favour, would you be able to measure from the back of your executive seats to the tail gate in order to close the tail lift. My problem is that I’ve got an aviation dog crate I’m hoping will fit and if not need to order a new one with a lead time of 6wks minimum.
Also do the executive seats when moved forward create more room in the boot so that I could look to remove the carpet flap at the rear of the seats positioned in the boot. Hopefully will fit just trying to cover all options. I would measure myself but the car is in Guildford and I’m not picking it up til the end of next week. Thanks in advance Paul.
Post #696032 11th Jul 2024 10:18pm
Paul, I've not got the executive seats in mine (prefer the flexibilty of being able to fold them for extra capacity) so I doubt I'm any use to you. But FWIW
With the seat backs fully reclined the measurment across the parcel shelf is 66cm
With them more upright its 77cm
Leaving this inside the car
Obviously the boot floor is much deeper but with the angles of the seat backs and tailgate its much smaller at dog height. Mike - MPx
Post #696051 12th Jul 2024 9:45am
Nabbler
Mike thank you so much for your time much appreciated
Post #696054 12th Jul 2024 10:04am
