Home > Technical (L322) > Ignition ON without the keys!!!!
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
One for the technical chaps here......
Cleaning the TDV8 yesterday and whilst hoovering in the drivers footwell I found a switch (near the OBD port) which looks like an electric window switch from a Mondeo Shocked Shocked
Pressed it both ways and discovered the same result........ Ignition comes on, radio comes on, steering wheel moves...... just like inserting the ignition key. All this while the keys are still in my pocket!!! Shocked Shocked Shocked
Any ideas??? Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #6833 10th Aug 2009 1:21pm
Martin
Site Admin
Any good? http://www.fullfatrr.com/forum/topic705.html?highlight=switch
Post #6834 10th Aug 2009 1:24pm
JMC
Cheers Martin. Except in that thread BBS says that pressing the switch should have no effect...... Confused
So, the answer is hinted at, but not at all clarified. In fact, I feel worse now that my switch seems to turn the car on with all but the starter Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #6836 10th Aug 2009 1:39pm
Martin
Site Admin
Is the relay fitted?
Post #6837 10th Aug 2009 1:42pm
JMC
Just been out to check......
+ve terminal of the battery has a substantial metal 'T-piece' attached to it. There seems to be some sort of relay connected under the 'T' from which the main (red) cable goes into the engine compartment - presumably for the starter motor. On top of the 'T' there is another cable attachment which runs into a plastic covered loom carrier at the back of the battery and goes off into the body - presumably for all the ignition-on items. Confused
There are no signs of anything 'left loose' or stuffed down the side of the battery at all. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #6838 10th Aug 2009 2:15pm
dan_uk_1984
I wish mine did this, when I'm detailing the interior I would like to have the radio on without the constant bong for leaving the key in the ign...
Post #6839 10th Aug 2009 2:47pm
Mine doesn't have the switch at all, I've looked all round the footwell area to find it.
Is this what the dealers use for cars in the showroom so that punters can alter seats etc without the keys being in? Often wondered how they managed that. Discovery 4 HSE
Post #6841 10th Aug 2009 2:53pm
JMC
No good for that..... What I omitted to say was that I had to keep the switch depressed (either way) to achieve the 'ignition on' result. Confused
Still not got an answer as to whether or not this is how it should be though. Neutral The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #6873 10th Aug 2009 10:17pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
On the other forum there's a post about this switch. No one knows exactly what it is for, but according to general knowledge, it has something to do with the times when you need to tow the car.
And for all i know, only 2007my-... have got this switch. All previous cars may have this switch somewhere else.
Post #6905 12th Aug 2009 10:11pm
dan_uk_1984
I always thought it was the transport mode switch so that when the car is strapped down on the low loader the suspension didn�t do anything. Much like the inhibit switch on the classics.
Post #6910 13th Aug 2009 12:26pm
Vogue
This is an odd one for the switch to turn the ignition on - over on RRNet, there is a thread about a similar switch being installed for US spec vehicles to disconnect the battery. This was to avoid battery discharge whilst the vehicle was being shipped to the US and in lengthy storage. As most of us know a battery on a FFRR discharges over a couple of weeks...
Post #6911 13th Aug 2009 4:43pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Yours lasts weeks mines days
Post #6915 13th Aug 2009 7:33pm
Vogue
have you checked and double checked the battery Ken, mine had a dead cell which speeded up the discharge to 2 or 3 days as well.
Two garages tested mine and said it was OK, I stuck out with the main agent who re-tested it and then found the fault...
LR replaced it under warranty.
Post #6920 14th Aug 2009 9:39am
dan_uk_1984
OR:
They found the "actual" problem and fixed that for 50p and then charged you/LR warranty �150 for a replacement battery?
Post #6924 14th Aug 2009 11:51am
Vogue
no definitely a new battery, saw them fit it.
Post #6958 16th Aug 2009 9:17pm
