Home > Technical (L322) > Refitting 2012 Parking Aid AH42-15K866-BG |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
AFAIK you can't fit used units as on first use it's locked to the car's VIN. The reverse camera is not part of the parking assist module awhich only runs teh parking sensors. I had to buy 2 new units after water ingress destroyed 1st one. The 2nd one I mounted upside down to stop water dripping down the wires. There is a known issue with an unknown leak source in the rear that takes out not only parking modules but also the audio units so another solution is to put a plastic sheet over everything tucking to top under the parcel shelf support. 2012 TDV8 Vogue (L322) |
4th Jul 2024 3:11pm |
robkuijpers Member Since: 11 Apr 2019 Location: Zeist Posts: 33 |
Thanks JayGee
4th Jul 2024 3:56pm |
Good to know used units work. I never found the leak either so but just went with a sheet of plastic. JLR must also be struggling as they fitted a plastic splash cover on the inside on later cars. 2012 TDV8 Vogue (L322) |
4th Jul 2024 6:11pm |
After doing a lot of experiments with the IIDTool, I discovered the following:
5th Jul 2024 4:13pm |
I seem to remember that when my PAM’s failed there was no light or tone and only got this when one of the sensor wires broke. 2012 TDV8 Vogue (L322) |
5th Jul 2024 4:20pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
this thread might be some use.
5th Jul 2024 4:23pm |
Thanks @Range Rover L322, very recognisable and helpful! In the mean time I also put a plastic cover sheet over all the electronics on the LH side.
7th Jul 2024 7:59pm |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 |
Hi Robkuijpers,
13th Dec 2024 11:12am |
Hi
13th Dec 2024 4:47pm |
Thanks Rob,
13th Dec 2024 9:38pm |
Well I have driven the car a few times and so far the 2nd hand module works perfectly. Was happy that I only paid £68 for the 2nd hand unit and it looks very clean. Will now work out a way to try and stop any water getting into it, I have reveiwed the other posts on here about this.
15th Dec 2024 11:25am |
