Home > Technical (L322) > Hdc fault, among others
Biffard
Hello all. Need a bit of advice. I’ve got a vogue 3.6 07 reg. had it 5 years and absolutely love it. presently it’s going into limp mode and showing a full house, Hdc fault, gearbox fault, suspension lowering etc. The thing is it’s always within half a mile from starting out first drive of the day and a switch off and switch on cures it. And it will be absolutely fine all day with many stop offs etc shopping for an hour and it’s fine. Just that initial start out. Any help would be gratefully received.
Post #695684 7th Jul 2024 8:04am
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Sounds like a failing battery. If the voltage is slightly low they can throw up various faults. This may be why it’s ok when it’s run a while and topped the battery up.
Post #695689 7th Jul 2024 11:05am
Biffard
That would make sense. I’ll change the battery first. I don’t suppose they last forever. Battery was replaced about 3 years ago but the car does sit on the drive all week.
Many thanks for your help.
Post #695701 7th Jul 2024 2:06pm
