![]() | Home > Technical (L322) > 4.4 tdv8 starter solenoid wiring mod |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
Either the solenoid or the starter. John
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 31 ![]() ![]() ![]() |
But there is no feed at the red wire in the fuse box |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2664 ![]() ![]() |
Presumably your new wire comes from the starter relay so is that relay operating? |
Hi Graeme's, no, I simply ran a wire from the red in the fuse board to the trigger. All other wiring is untouched. I took that info from the long post on here re starter issues
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 56 ![]() ![]() ![]() |
I think I recall reading somewhere that there’s a 400A fuse under/near the battery. If it’s this high at 400A, I suspect it’s supplying the starter. So might be worth looking at circuit diagrams and see if this fuse exists, and if it does you can check that. |
Which red wire in the fuse panel and under what circumstances does it have power? I didn't run an alternate wire so I didn't look at what would be involved in doing so.
Hi graeme, firstly thanks for your help. I have resolved the issue purely by chance. I swopped the relays and the fault remained. I checked ll fuses and all still fine. In the end, I must have had a bad contact on the multi plug with the 4mm red wire. It started straight up and code has cleared. All I did was fiddle with the connector. I'm now reluctant to modify the wiring in case something fails again. Thanks |
Hi all,
Superjoey43 Member Since: 12 Nov 2024 Location: Llanrwst Posts: 1 ![]() ![]() |
Hi, I'm trying to find the beginning of the "relay to solenoid mod for starting issues on 2010 tdv8 4.4 "
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Welcome.
