Home > General (L405) > Corrosion on Scottish L405's
chrisnj
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Baltic Blue
There seems to be anecdotal views and some old threads on the subject but does anyone have close experience, rather than bloke down the pub said experience, of secondhand L405's that have lived their life so far in Scotland being more corroded than a car that has lived mostly down south?
Anyone bought a Scottish soured L405 and then found corrosion problems?
Personal thoughts having read a lot about it on this and other forums is its less of an issue now that maybe it would have been 20 years ago but myths persist once they are established.... Like I say looking more for hard experience than further regurgitation of hearsay Very Happy ----------- Current Garage --------------------
2011 Range Rover L322 5.0 S/C Autobiography
2015 MINI JCW Hatch
2006 BMW 650i V8 Conv
1997 Range Rover P38 4.6 V8 HSE
2014 Harley Davidson Fat Bob
Post #694769 20th Jun 2024 2:01pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
My L405 spent its first 7 years in Cupar and Edinburgh and apart from the fuel tank cradle the underside is in remarkable condition. I'd be more worried about a car that lived by the seaside.
Post #694777 20th Jun 2024 3:43pm
fisha
I’d say it’s more whether it drives on gritted/salt roads. Mine came from North Yorkshire and I would say it looks like it it’s lived round my way all its days ( on the Clyde … so does get salt sprayed from time to time in bad weather as well as the salted roads in winter ) V8 or else ...
Post #694788 20th Jun 2024 5:23pm
Mikey
Ah, corrosion Laughing Big Cry
All 405/494
Post #694793 20th Jun 2024 6:20pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Wow 😮 I feel your pain.
Post #694799 20th Jun 2024 8:14pm
CS
Mine (MY17, 65,000 miles) has had the following corrosion issues:
Galvanic corrosion to bolts behind/around headlights under bonnet
Parking sensor failure due to delamination of surfaces, some rear ones replaced twice
Aluminium strip across tailgate replaced twice
Corrosion under door handle paint
Corrosion of bolts under flap between body and lower tailgate
Corrosion of rear anti roll control pipework (expensive as rear subframe needs to come off to replace)
The towbar armature (farmer's hitch) is really rusty, the anti-rattle bolt needs to be replaced periodically as it rusts solid and the hole for the pin needs to be filed out to allow the pin to locate.
Some of these occurred during the warranty period and were covered by LR. Only Range Rovers since 1988
Post #694823 21st Jun 2024 10:27am
fisha
Mikey, for those corroded body mounts, is there a solution/fix to that ? Ie can it be repaired in some way ? V8 or else ...
Post #694909 22nd Jun 2024 8:47pm
I wouldn't buy one that had lived in scotlandshire as almost all I see have bad corrosion issues... Sorry but a simple fact... Thumbs Up
Post #694919 22nd Jun 2024 11:09pm
^^Having lived there for some years l would totally agree. Even now l wouldn’t buy a car that had lived its life in Scotland.
Post #694923 23rd Jun 2024 5:49am
Mikey
Given the bodies are bonded together, I have no idea how to repair
Alu wleding isn't as straight forward as traditional MIG welding
Post #694927 23rd Jun 2024 7:26am
Mikey
We have a customer who buys cars from London and brings them up here. They are an absolute joy to work on Rolling with laughter
Post #694928 23rd Jun 2024 7:27am
chrisnj
Thanks guys - So the consensus seems don't buy cars with a Scottish heritage - Sorry Scotland! I'll cross off cars from there from my search. Saves me a long trip for collecting Very Happy ----------- Current Garage --------------------
2015 MINI JCW Hatch
Post #694933 23rd Jun 2024 8:30am
For the rear subframe mounts I would think Tig welding would be best but you will need to find an experienced welder who is willing to weld aluminium upside down, it's not easy...
When I looked to pre-empt my rear subframe removal I found a few mobile guys doing Tig welding
I expect we will see someone doing it soon on here....
I've just bought one of these to wash it off regularly underneath during the salting of the roads...
https://www.amazon.co.uk/dp/B0BYSF2Z5R?psc...ct_details Pete
Post #694943 23rd Jun 2024 11:40am
fisha
Was just reading up about tig welding and that it’s not recommended for cars due to the huge RF noise it generates and that TIG is best when parts are removed or not connected to the car. So you fall back to MIG welding.
I have a dread that mine will be as bad as some of those pictures so I’m already thinking around what would I do to fix it. V8 or else ...
Post #694957 23rd Jun 2024 5:26pm
Weird, I've seen Tig welding on lots of cars, maybe there is a work around for it...
Mig tends to have a larger weld pool so is probably even harder than Tig welding to do upside down...
We need some first hand experiences. Thumbs Up Pete
Post #694980 24th Jun 2024 8:58am
