Home > Maintenance & Mods (L322) > L322 woosh/resonance on gear change
Lordy9099
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hi All,
For a while now I've had a sort of woosh/resonance around 1,200-1,600 RPM usually around when it changes gear. It doesn't sound like it's gearbox related as it comes from towards the front of the vehicle. Initially I thought it could be turbo related but it seems very odd as it's not a whine noise. I'm starting to think it's possibly air or boost leak related but don't have any codes thrown up or any limp mode in anyway.
Anyone had this or any ideas?
Thanks
Post #694587 16th Jun 2024 9:46pm
JayGee
The splash / heat sheild under the gearbox can resonate and make this kind of noise. Loosening and retightening the securing bolts can fix it or putting a thin layer of sound deadening sheet between it and the 'X' brace under the box fixed it for me. 2012 TDV8 Vogue (L322)
Post #694589 17th Jun 2024 7:11am
toby1
Does it happen when it is cold or only up to temperature?
Post #694603 17th Jun 2024 1:44pm
Lordy9099
Both but more noticeable when warmed up.
Post #694844 21st Jun 2024 3:54pm
Lordy9099
Anyone have any ideas? Sound is very similar to the noise a snorkel would make.
Post #695310 30th Jun 2024 7:49pm
kevinp
Does it do it in sports mode?
Post #695316 1st Jul 2024 12:55am
JayGee
To avoid speculation just take it to a garage and get them to do smoke tests on the intake upstream and downstream of the turbo. 2012 TDV8 Vogue (L322)
Post #695320 1st Jul 2024 5:56am
