![]() | Home > Maintenance & Mods (L322) > L322 woosh/resonance on gear change |
The splash / heat sheild under the gearbox can resonate and make this kind of noise. Loosening and retightening the securing bolts can fix it or putting a thin layer of sound deadening sheet between it and the 'X' brace under the box fixed it for me. 2012 TDV8 Vogue (L322) |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 184 ![]() ![]() |
Does it happen when it is cold or only up to temperature? |
Lordy9099 Member Since: 22 Jul 2023 Location: Manchester Posts: 22 ![]() ![]() ![]() |
Both but more noticeable when warmed up. |
Anyone have any ideas? Sound is very similar to the noise a snorkel would make. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 ![]() ![]() ![]() |
Does it do it in sports mode? |
To avoid speculation just take it to a garage and get them to do smoke tests on the intake upstream and downstream of the turbo. 2012 TDV8 Vogue (L322) |
