Home > Technical (L322) > P0741-00 Torque converter clutch solenoid fault |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 960 |
In controlled-slip mode in 4th gear the engine speed typically leads the turbine speed by 3-4%, with full lock-up in 5th & 6th gears.
18th Jun 2024 7:08pm |
craigjbrown Member Since: 16 Jun 2024 Location: Glasgow Posts: 4 |
Hi phill thanks for your reply,
19th Jun 2024 7:50pm |
For what it’s worth, I think you’re taking exactly the right approach to diagnose your issue. The controller is flagging that the lock-up clutch is sticking and failing to lock when requested. You’ve changed the fluid, filter & EDS 6 solenoid.
19th Jun 2024 10:10pm |
Thanks for your reply Phil. in talks with Sussex auto just no. |
20th Jun 2024 8:45pm |
