Home > General (L405) > Diagnostics scanner |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 |
The GAP IID is the weapon of choice for 99% of JLR DIYers. 2012 TDV8 Vogue (L322) |
2nd May 2024 9:22am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 409 |
2 votes for GAP IID - but you need the right version to work on a 2018 vehicle.
2nd May 2024 11:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35086 |
GAP iidtool , the best out there.. ... - .- -.
2nd May 2024 12:18pm |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 120 |
If you own several cars then there are advantages in going for a non specific LR tool. I own an iCarsoft CR Max and have used that on my L405 to live data AC pressures and temperatures when adding in refrigerant. I've monitored the transmission oil temperature when I changed the oil and sump. I've reset the service notification. I've pinpointed a Maff issue on one inlet and changed the sensor. I've done a battery reset after changing the battery. It has lots of other features I haven't needed to look into such as with air suspension calibration.
2nd May 2024 1:48pm |
Coxy996 Member Since: 02 May 2024 Location: Buckinghamshire Posts: 7 |
Hi Baz, thanks for your input, what year is your RR? |
12th Jun 2024 11:46am |
2016 SDB8 |
12th Jun 2024 1:26pm |
