Home > Technical (L405) > L405 P2265-64 Water in fuel sensor-circuit range/performance
Mariusses
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I was wondering if anyone else has experience the above code .
New fuel filter has been fitted, sensor replaced, I even disconnected the plug but still same fault comes up.
I run out of ideas.
Car is a L405 4.4SDV8
Many thanks.
Post #694143 9th Jun 2024 7:02pm
TST717
I have just had the same error message ……water in fuel present /restricted performance and vehicle went into limp mode … not sure if it is an actual issue , we have had quite a bit of flooding /water on roads and we were out in these conditions but I thought that the RR should be able to cope with that !
Did you ever resolve it ?
I was tempted to reset but I am a bit wary in case there is really an issue ….it needs a service anyway so I might just get them to advise while they are at it
Post #708103 2nd Jan 2025 3:43pm
Kot
Reset it, if it comes back straight away it is an issue. 2018 SE SDV8 4.4 Byron Blue
Post #708105 2nd Jan 2025 3:49pm
TST717
Now that’s a fair comment , worth a shot …. Thanks for that …!
Post #708106 2nd Jan 2025 3:51pm
