Home > Technical (L405) > Brake service question.
TDFJ
United Kingdom 2007 Range Rover Vogue SE TDV8 Epsom Green
Im sorry if this has been done to death, I looked through the forums and couldn't see it addressed anywhere..
L405 Brakes: Front and rear Disc and pad replacement - quoted over £2000 by main dealer.
I'm not sure they even need doing,
this is the Main dealer 'Triage report' -
Brakes, Front, Front pads, 7mm disc lipped and corroded £ 1157.16,
Brakes, Rear, Rear Pads 5mm discs corroded and lipped £ 890.75
While I'm at it, they quote:
Rear Diff Pinion seal leaking will require new Diff Pinion Seal. £ 911.45
Am I being taken for a ride or do you feel these are fair? (I don't even know if the quote includes labour!)
Alternatively, any suggestions for a good independent workshop near Beaconsfield?
Many thanks
Post #694129 9th Jun 2024 3:35pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I did Brembo front and rear discs and pads for £800 DIY including VAT. £1k plus VAT for labour is a bit rich for a job that took me 4 hours and a workshop should be faster than me.
Pinion oil seals are another relatively easy job, I have never done one on a RR but I have on other cars and its usually a £20 seal and a couple of hours work removing shafts and failed seal then refitting. You have to be careful with failed pinion seals as they can throw out the oil and empty a diff pretty quickly.
I think they are quoting you book times which are usually generous with labour at £250/hr plus VAT.
Post #694133 9th Jun 2024 4:06pm
TDFJ
Thank you for your reply.
That's really interesting.
I'm guessing that's going to be the going rate at any Main dealer then.
Post #694134 9th Jun 2024 4:08pm
baz000000
You should seek out an independent, they are usually around £80/hr plus VAT.
Post #694135 9th Jun 2024 4:11pm
