![]() | Home > Technical (L405) > AIR CONDITIONING NOT WORKING! |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 141 ![]() ![]() ![]() |
You can hot wire the clutch on the compressor pulley to force the compressor to run.
Big Yorkshire pudding Member Since: 09 Dec 2023 Location: Barnsley Posts: 15 ![]() ![]() |
That seems good advice, the system was totally emptied when the engine was taken out. I did not see the pressures or any quantities which was put in the system when filled . I will have to try to get the live readings on my code reader. Thank you. |
