Home > Technical (L322) > 2011 4.4TDV8. More oil leaks and burning oil smell...
BBryant
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I have had my pil cooler replaced but still have a burning smell coming in the cabin after a motorway run. I have been under today and found the below leaks, any advice would be welcome.
Pipe on the drivers front, just in front of the wheel. I am not sure what this is for or how to fix it.
A small patch of oil on the rear of the engine, cant see where this is coming from and doesn't seem to be dripping
A small grease leak from my steering column
Advice on if you think it could be the problem and how to fix it welcomed!
Post #693937 5th Jun 2024 6:54pm
DrRob
I'd be taking it back to whoever did the job for you. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #693956 6th Jun 2024 8:08am
BBryant
It is going back to them soon for a MOT so will be getting them to have another look then. I don't think the front flexi hose will be related to the oil cooler though will it? I am not sure what that hose is for. It seems to be a swaged end so no way to tighten it as far as I can work out
Post #693959 6th Jun 2024 10:04am
DrRob
That flexi is a power steering hose
Smell could be residual oil still burning off from the cooler leak but they should have cleaned that all off.
Did they put new Viton o rings on the turbo feed pipe on rear of cooler. They leak. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #693962 6th Jun 2024 10:14am
JayGee
Re: 2011 4.4TDV8. More oil leaks and burning oil smell...
I assume you mean oil cooler?
There is usualy a resudue of oil leftover from a leaking cooler which may take a while to clear but worth getting the garage to check it anyway. 2012 TDV8 Vogue (L322)
Post #693963 6th Jun 2024 10:14am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Had the same on mine. Replaced the oil cooler and still had the smell. It took a couple of runs before it was finaly got rid of.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #693964 6th Jun 2024 10:40am
BBryant
Thanks DrRob, I will see about getting that replaced when it goes in for the MOT, it is the only actually leaking rather than seeping leak I can find. As I only smell burning after a motorway run, I'm thinking that it is the only time the windspeed is high enough to blow it back to the exhaust from the front of the engine.
JayGee, IGP, I should have said it is over a month since I had the cooler done, I'd have expected it to have burnt off by now.
Post #693973 6th Jun 2024 11:22am
fmgl322
Germany
It took mine ages to burn off residual oil spills after replacing the oil cooler. At least 2 months, mainly motorway driving. -------------------------
2012 4.4 TDV8 Vogue
2001 Audi A2 1.4 16V
2019 Skoda Kodiaq (don't ask...)
Post #694002 6th Jun 2024 10:39pm
BBryant
Thats good to know, I don't do that regular motorway driving, not crawling around but more A roads not over 50mph.
Post #694014 7th Jun 2024 6:57am
BBryant
I was under the car last night, again...
I have noticed what I am fairly sure is the secondary turbo through a small cut out in the offside front wheel arch. Looking where the arrow is in this photo
I can see this...
Which when looking closer seems to be leaking oil out of the rear of the turbo
What do we think about this? I am going to take the wheel arch liner out when I have a chance and have a closer look. I am hoping it is just a loose jubilee clip. I regularly give it a good thrashing to get the secondary turbo running, I haven't seen any smoke out of the back in the whole time I have owned it.
Post #694015 7th Jun 2024 9:02am
