![]() | Home > Technical (L322) > l3224.4 tdv8 air con advice |
condenser valve. best option is to replace condenser. |
PAYNTS Member Since: 23 May 2024 Location: Bedofrdshire Posts: 13 ![]() ![]() ![]() |
Thanks for the heads up about the condenser what about the temp sensor on the control panel I’ve seen other videos where they’ve dismantled this - would the air con work without the temp sensor reading - and surely it should read ?? |
