Home > Technical (L322) > l3224.4 tdv8 air con advice
PAYNTS
Hi all I’ve got a 2012 4.4 tdv8 and the air con has stopped working my gapIID doesn’t come up with a fault but it tells me there is pressure in the system. And it tells me there’s power going to the AC pump (clutch I presume) it also reads N/A. For the interior temp sensor. Does anyone have any experience regarding the heating and air con system im thinking my pump is knackered ?
Post #693914 5th Jun 2024 10:44am
Dolphinboy
condenser valve. best option is to replace condenser.
Post #693915 5th Jun 2024 10:46am
PAYNTS
Thanks for the heads up about the condenser what about the temp sensor on the control panel I’ve seen other videos where they’ve dismantled this - would the air con work without the temp sensor reading - and surely it should read ??
Post #693916 5th Jun 2024 10:53am
