Home > Technical (L460) > Wifi Hotspot and Data Plan
Crocs
Land Rover have now found a way of charging for the Data Plan and will be charging me £420 a year from the end of July. I don't use the wifi much, so £420 would not be worth it.
Don't laugh, but I manage with an iphone on calls/texts and 1GB of data for £5 per month (no, it's not steam driven!). I know I could add more and use the phone as a hotspot, but is there any way I can get the eSim in the car to link to another provider so that I could buy an annual plan with, say, 20/30GB?
Post #693910 5th Jun 2024 9:40am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I do not understand what this is or what it does for anyone and when I asked the stealer they clearly did not either. letters not necessarily in the right order
Post #693954 6th Jun 2024 5:28am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Not sure if it's applicable but I just swopped to SMARTY for my phone (sim only). Unlimited calls and texts and 50GB of data for £8 per month.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #693969 6th Jun 2024 10:58am
Crocs
Yep, that's probably what I'll do, failing being able to connect the eSim in the car.
Post #693979 6th Jun 2024 1:33pm
calicoj
Spain
The optional data plan (free for the first year) serves two main purposes:
1/ it provides a shared internet connection to passengers via a wifi hotspot.
2/ it allows the car's optional apps, such as Spotify or Amazon Music, to stream from the internet without requiring CarPlay or Android Auto.
I renewed mine for another year a week ago, simply because I prefer the Spotify interface on the car than in Carplay. I also like to be able to continue using Spotify when I forget my phone at home.
Other than those two use scenarios, it's not necessary, as the car's connected features (Remote, etc.) use a different internet connection that remains active regardless of whether or not you buy the data plan.
Post #694173 10th Jun 2024 6:05am
Dixy
Thank you
I now know that as long as anyone in the car has their phone it is totally pointless. letters not necessarily in the right order
Post #694178 10th Jun 2024 7:46am
Crocs
The only other advantage is that there is the potential for a better signal as the car system is connected to an external aerial.
But, at £35 per month, I'll not be renewing and just use phone as hotspot.
Post #694183 10th Jun 2024 8:12am
Bill
Dixy & crocs, that’s the conclusion I came to as well. Wasn’t quite sure so your confirmation helps! Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #694190 10th Jun 2024 10:36am
5.0
I did not renew mine. I can’t see any advantage over using a phone as a hotspot. The Spotify interface is exactly the same on PiviPro as it was before. Also I think when your phone is connected to the car it uses the external antenna anyway.
Post #694204 10th Jun 2024 12:46pm
