Home > Technical (L405) > Constant Oil Leaks |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 313 |
Did you put a new oil cooler in? They often warp apparently (like yours). |
2nd Jun 2024 9:31am |
TheLandy3000 Member Since: 02 Jun 2024 Location: Brisbane Posts: 5 |
Hi Richie,
2nd Jun 2024 11:00am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2382 |
Its not unreasonable to find that new gaskets on a warped housing prevent leaks for a short while until they have been heated a few times. |
2nd Jun 2024 11:25am |
Yeah, you definitely should change the cooler. Mine leaked a few months ago and I changed the cooler. Job done 👍 |
2nd Jun 2024 12:12pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 162 |
Same here, had the usual oil leak from the oil cooler and was recommended to replace the oil cooler as there are very susceptible to warping and even cracking so for a few hundred pounds (OE approx £450 but good after market ones can be bought for a couple of hundred) I replaced the whole lot, job done, should not need to worry about again for quite a few miles. _______________________________________________
2nd Jun 2024 5:21pm |
Hey Guys,
5th Jun 2024 9:49am |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 |
Is this what you mean, the torque for the oil cooler bolts? 13nm according to the workshop manual in the forum Wiki.
5th Jun 2024 9:35pm |
No, the bolts holding the oil cooler to the casting, see the image below, there's 6 of them but you can only really see 3 of them and in the manual there no torque setting for them. There probably 13NM but ill check it once I get the new unit as I haven't seen anyone post the torques on the forum anywhere though I could have missed it somewhere.
6th Jun 2024 12:49am |
You shouldn't need to touch those bolts if fitting a new oil cooler assembly as they hold the 2 halves of the oil cooler together. The other bolts hold the complete oil cooler assembly to the EGR cooler.
6th Jun 2024 1:45am |
Ah, I can’t see the image you posted (on my mobile) but I think you’re referring to the cooler part of the combined oil filter/cooler assembly. As far as I’m aware the replacement ‘oil cooler’ only comes as a complete cooler and filter assembly I.e the cooler part isn’t available separately.
6th Jun 2024 1:56am |
Hi Guys,
20th Jul 2024 2:40am |
