![]() | Home > Technical (L405) > Constant Oil Leaks |
TheLandy3000 Member Since: 02 Jun 2024 Location: Brisbane Posts: 10 ![]() ![]() ![]() |
The oil cooler and heat exchanger are both the same thing, I'm not sure what the correct term is for the cast housing underneath (part the oil filter screws into), I would call it a directional housing. The housing underneath all that is another heat exchanger for the EGR system but that only has coolant and exhaust gases running through it from what I understand, there is a small channel for the oil to go back into the engine in that housing.
IRBails Member Since: 25 Jan 2016 Location: Shellharbour;NSW Posts: 14 ![]() ![]() |
If I understand you correctly you are saying the housing that the oil cooler was attached to was the issue.
No, the cast housing was fine, it was the actual oil cooler/heat exchanger that was bent (the rectangular part on top) it was slightly bent on the surface were the gasket seals to but it was enough to cause it not to seal. It also means you can get the wrong torque figures when torqueing it down as you torqueing against the bend in the exchanger as well as the gasket and casting. When you think about it, in cold climates this part could easily experience temperature differences from -40c up to 140c once warm and under load. It could be the casting as well, I reused the casting once before replacing the whole assembly and it didn't leak where it went on to the tower but did between the heat exchanger and the casting. It also could be the bolts too as the bolts have a shank on them where they become skinny, this indicated these are a torque to yield bolt and are intended for a one time use.
I have already replaced the oil cooler, used the Nissan which was much cheaper. So need to assume that it isn't sealing properly . I had it fitted by a Land Rover tech am\nd the supply was TR spares who recommended the Nissan product.
No, I made the mistake of thinking the bend in the oil cooler wasn't to bad and reused the original oil cooler, I should have remembered that aluminium grows/expands when hot so the bend becomes worse with heat. I don't personally trust aftermarket brands unless there the OEM for the manufacturer or they have a really good reputation for quality. I have been told that Nissen is good though and i think a OEM for other brands.
Done the O rings twice used the CAT ones 2nd time round no leaks from that area. There is some oil around bottom of oil cooler, as said very small leak, I am thinking it is a gasket leak from the oil cooler.
