![]() | Home > Maintenance & Mods (L322) > Deployable steps bracket replacement |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 ![]() ![]() ![]() |
I managed to break the drivers side rear bracket on the retractable side step a while ago. I’ve finally found a metals expert who can make me a new one if I can get one for him to make a mold from. Taken the steps off the other side and can’t figure out how to get the bracket off. No videos on the net on how to do it. Has anyone here removed them?
I saw that, but decided to try locally in case of any fitment issues Current:
woodrjh Member Since: 13 Sep 2021 Location: Burgess Hill Posts: 26 ![]() ![]() ![]() |
Well, it’s arrived. Ordered on the 22nd May, arrived today 31st.
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Be interesting if this works or not, the other l322 we have in the family has a broken bracket too so we are on the look out to replace it. |
It’s on the car now and it’s working well. I have already replaced the front bracket on that side and I’ve never seen the steps move as smoothly since I got the car 3 years ago.
Thanks for the update, probably worth a try. |
bearhouse Member Since: 18 Jul 2020 Location: Hemel Hempstead Posts: 10 ![]() ![]() ![]() |
How did you remove the motor assembly from the original bracket setup? I've removed all the bolts but it won't come apart. I've tried hitting the motor shaft and started to damage it. But, I still wont come apart. Does it need a hydraulic press or is there a trick to get apart. I've thought about buying a new motor to fit to the new bracket but again if a hydraulic press is required, that will be a problem.
When I replaced the front bracket, I have a small 12 ton hydraulic press, but it broke the bracket as I was pressing the motor out.
As for removing the bracket, it's a little fiddly, but not difficult.
Thanks Rick for all the help and advice.
