Home > In Car Electronics (L322) > mp3 discs
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
mp3 discs
I have decided to copy some albums to mp3 discs for a long journey (the wife and i have completely different tastes!). Being non 'mp3' technical what would the file structure look like on the disc?. Also anything i should pay attention to?.
Thanks in advance
Post #67268 6th Jun 2011 6:05pm
daveo
you will find if you have a 2006 onwards to be safe..the cd player should support mp3's, just drag them to the disc dont make any files or it wont see them. V8 facelift Range Rover Autobiography 22" wheels.
Post #67286 6th Jun 2011 7:04pm
MP3 discs work on all touch screen systems, you can see those in 54 plate cars too.
 Discovery 4 HSE
Post #67292 6th Jun 2011 7:16pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
It will only read one folder deep on Mine (MY2006 with touch screen)
MP3CD
---HitsCD1
---HitsCD2
---HitsCD3
It won't read:
MP3CD
---HITS
-----CD1
-----CD2
-----CD3
If that Makes sense Very Happy
Post #67310 6th Jun 2011 8:06pm
DavidP
So instead of using something like pinnicale instant to copy i can just 'drag and drop' ?. They are audio cd's so somehow i have to convert them to mp3. Once converted can i drag and drop as album1 tracks1-10, album2 tracks1-10 etc etc or do i need a root file.
I can confirm it is a touch screen 2006.
avi - i think it makes sense, i'll try it tomorrow.
Post #67311 6th Jun 2011 8:09pm
daveo
david sent you a pm V8 facelift Range Rover Autobiography 22" wheels.
Post #67333 6th Jun 2011 8:43pm
I used Roxio and Nero to create a data disc and yes, just drag and drop till the disc is full.
A word of warning: DO NOT put CD labels on the discs. They can bubble up and get stuck.
 Discovery 4 HSE
Post #67338 6th Jun 2011 9:02pm
daveo
good point RRUK and stick to good branded cdr, i always go for tdk. V8 facelift Range Rover Autobiography 22" wheels.
Post #67342 6th Jun 2011 9:23pm
fe600
2007 Range Rover Vogue TDV8 Chawton White
RTFM - Read the f..ing manual
You can put up to 20 folders on the disc.
Up to 20 letters for each track and each folder.
Up to 50 tracks in the root and each other folder.
It tried a disc with 100 tracks direct in the root -> only the first 50 will be available.
You can also use CD-RWs!
Post #69342 20th Jun 2011 2:59pm
DavidP
fe600. Many thanks indeed for your comments.
Post #69349 20th Jun 2011 4:00pm
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
If you have access to Gracenote to automatically label everything then burn with Nero - preferably Nero Express - you get perfect results . Nero will also convert to Mp3 from other formats for you. If you have a lightscribe burner you can put a label on as it prints direct on the disc. Under no circumstances use a paper label - do you fancy having to remove the whole unit if it comes off and jams everything......? Thumbs Up 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #69362 20th Jun 2011 5:38pm
simon1233
If you have itunes the files purchased form the store are not compatible with the system. You need to convert them to MP3 which iTunes can do for you surprisingly easily....
Post #69405 20th Jun 2011 8:14pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I can confirm fe600s comments, I initially burnt a cd with around 280 tracks in the root and could not read past around 50, so , as they were just a mix of tracks, I created folders called A-D E-H I-L etc and put the artists under their relevant folder associated with their name, then was OK. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #70433 29th Jun 2011 12:34am
just0007
Sorry I know I am being stupid but I have tried numerous times, how do I get my tunes from my I tunes to range rover so tracks are displayed on the screen. Please help I have tried to convert to mp3 clicking the box in I tunes only to get problem box appear . Big Cry
Post #72033 11th Jul 2011 7:14pm
simon1233
To convert files bought from the iTunes store to MP3 (I don't know if this will work with older files that have full DRM on them, but give it a try, it can't hurt...) go to your preferences and select the import preferences to be MP3.
Then highlight the albums/files you want to convert, right click, select 'create MP3 version' from the drop down option box and let iTunes do it's thing. You will then have an album list of duplicates - in your preferences tab make sure that you have file type selected in the view option. In your duplicated list you can click in the file type header to sort the list by file type. Simply copy the MP3 versions to a folder on your desktop and then onto a disk.
As others have said, keep the disk structure to be one folder per CD (if that makes sense) as the system only recognises/navigates one folder deep. I normally get about 7 or 8 albums per disk. Thumbs Up
Post #72046 11th Jul 2011 8:17pm
