Home > Maintenance & Mods (L322) > Belts, pulleys, Idlers & tensioner kits |
Folkert Member Since: 21 Mar 2024 Location: Le Mans Posts: 10 |
Hi All,
28th May 2024 8:49pm |
o dear, there's nothing else we can do about squeeky belts? I'm not into spending 1000 euro on replacing belts etc while it wasn't their time yet and will squeek anyways...
28th May 2024 9:56pm |
For everybody's reference this is the list of parts included in the original kit for a 2010-2012 4.4 TDV8:
28th May 2024 10:13pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Maybe first identify the source of the squeak as replacing everything may be overkill. Spray some water on the running belt and if it stops the noise it's a worn or contaminated ( Oil or antifreeze) belt or a tensioner gone weak and you could get away with just replacing these. If it doesn't stop the noise then it's a pulley bearing (inc alternator bearing) which is going to be a more expensive and involved job. The difficult practical part is removing the fan and shroud to get access which is why people recommend replacing everything inc other 'service items' - waterpump, alternator and AC compressor if they can afford it in one hit to avoid having to do it again. 2012 TDV8 Vogue (L322) |
29th May 2024 6:50am |
Thank you for the reply! My local garage guy indeed did the water test and the squeek dissappeared instantly. But indeed as you say to dive in deep and spend some time changing a belt makes me wonder if i should do it all so i will not be suprised by a tensioner issue in a few months …
29th May 2024 7:13am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
For parts I found auto-doc.fr to be a good site. I used them when living in France and have also used their UK site when back in UK.
29th May 2024 10:31am |
Ha yes auto-doc, i remember seeing them on Sams youtube videos product placement does work lol. Thanks for the tip! 2012 L322 4.4 TDV8 VOGUE
29th May 2024 11:21am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 |
am sure this has been answered but is it not possible to just replace bearings? Its actually a sport
1st Jun 2024 12:12pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
There is a factory upgrade tensioner LR022810 worth doing. 2012 L322 4.4 TDV8 AB low mileage - a peach
1st Jun 2024 2:24pm |
nice info!!! thanks for that.
5th Jun 2024 4:38pm |
Update:
6th Jul 2024 8:08am |
