Home > Maintenance & Mods (L322) > A little reminder |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
Better happening then rather than when out on the road. John
25th May 2024 7:59pm |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 139 |
Very true! We’re off on holiday soon glad it didn’t happen then miles from home! 1972 Series 3 full of character
26th May 2024 7:24am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 |
Glad to be of service! The older I get, the more I realise that people confuse wrinkles for wisdom |
26th May 2024 7:48am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Best to replace the other side as well if the leak was age related rubber deterioration. 2012 TDV8 Vogue (L322) |
26th May 2024 7:53am |
I was apprehensive until I found your guide - ‘First thing to say about the front strut replacement on the later 4.4 TDV8's is that it's much easier that anyone might expect. We are talking about undoing five nuts on the wheel, three nuts on the strut, a small brass nut for the air, a couple of torx screws and three nuts up top! That's it!!’ Have to say it’s one of the easiest jobs I’ve done!! 1972 Series 3 full of character 1985 90 pick up went anywhere 1992 90 Exported 2007 L322 that was an experience 2010 D4 more versatile than a Swiss army knife, now gone 2011 L322 4.4 VSE |
26th May 2024 11:36am |
I have been thinking this, but where do you stop? Just the other side or all four corners?? 1972 Series 3 full of character 1985 90 pick up went anywhere 1992 90 Exported 2007 L322 that was an experience 2010 D4 more versatile than a Swiss army knife, now gone 2011 L322 4.4 VSE |
26th May 2024 11:38am |
Both fronts on mine were perished equaly badly and so replaced both when one got a leak
26th May 2024 12:07pm |
Just the other side is enough. Rears are much less of a concern. It's not a question of IF, but WHEN the other side will go the same way. On top of this, we are talking about the equivalent of the springs and shockers on a 'normal' car in one unit. You really ought to do both sides at the same time. The older I get, the more I realise that people confuse wrinkles for wisdom |
26th May 2024 10:15pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
These are one of the easiest things I’ve done on the car, I changed each side on mine in 30 mins from wheels off to wheels on, did one side in my lunch break at work in the rain so was glad it was fast!
27th May 2024 8:32am |
I was pleasantly surprised by how easy it was which partially offset the cost. With the benefit of hindsight I’d have just changed the bags. 2012 TDV8 Vogue (L322) |
27th May 2024 9:10am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
You two were lucky, those 2 bottom bolts can be a bit troublesome to say the least, as can one of the ball joints.
27th May 2024 12:50pm |
Price of a pair or front struts with variable damping is not at all cheap though. Where did your seals leak when you tried it? 2012 TDV8 Vogue (L322) |
27th May 2024 4:44pm |
Yes- I must admit I was expecting a fight from these, but they came off first time, I didn’t undo any ball joints luckily 2009 (2010 MY) 5.0 Supercharged Autobiography 2007 TDV8 Vogue SE 2005 BMW E63 645ci 2024 Porsche Macan |
28th May 2024 3:28pm |
i've ordered the passengers side, fingers crossed its just as easy!!! 1972 Series 3 full of character
28th May 2024 4:46pm |
