Home > Maintenance & Mods (L322) > A little reminder
Andyyav
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
A little reminder
Was planning on changing my gearbox oil and filter, stuck it in off road height, axle stands etc ready to go, thought I’ll just check the oil temp on the GAP tool and as I did a big rush of air from the front right and down it went, air bag had a sudden failure,
A little reminder I thought to always stop and think before ‘just having a quick look’ under these beasts
On a brighter note the old one came off fairly quickly (following JMCs guide) and I managed to get a replacement on a Saturday delivery from advance factors!
[/url] 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE
Post #693307 25th May 2024 7:20pm
Weegie
Better happening then rather than when out on the road. Thumbs Up John
GAP iiD BT
Post #693309 25th May 2024 7:59pm
Andyyav
Very true! We’re off on holiday soon glad it didn’t happen then miles from home! 1972 Series 3 full of character
1992 90 Exported
2011 L322 4.4 VSE
Post #693336 26th May 2024 7:24am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Glad to be of service! Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #693340 26th May 2024 7:48am
JayGee
Best to replace the other side as well if the leak was age related rubber deterioration. 2012 TDV8 Vogue (L322)
Post #693341 26th May 2024 7:53am
Andyyav
I was apprehensive until I found your guide -
‘First thing to say about the front strut replacement on the later 4.4 TDV8's is that it's much easier that anyone might expect.
We are talking about undoing five nuts on the wheel, three nuts on the strut, a small brass nut for the air, a couple of torx screws and three nuts up top! That's it!!’
Have to say it’s one of the easiest jobs I’ve done!! 1972 Series 3 full of character
1992 90 Exported
2011 L322 4.4 VSE
Post #693350 26th May 2024 11:36am
Andyyav
I have been thinking this, but where do you stop? Just the other side or all four corners?? 1972 Series 3 full of character
1992 90 Exported
2011 L322 4.4 VSE
Post #693351 26th May 2024 11:38am
JayGee
Both fronts on mine were perished equaly badly and so replaced both when one got a leak
I checked the rears and couldn't see anything like the same problem so left them alone. 2012 TDV8 Vogue (L322)
Post #693352 26th May 2024 12:07pm
JMC
Just the other side is enough. Rears are much less of a concern.
It's not a question of IF, but WHEN the other side will go the same way. On top of this, we are talking about the equivalent of the springs and shockers on a 'normal' car in one unit. You really ought to do both sides at the same time. Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #693399 26th May 2024 10:15pm
TDV8 Paul
These are one of the easiest things I’ve done on the car, I changed each side on mine in 30 mins from wheels off to wheels on, did one side in my lunch break at work in the rain so was glad it was fast!
Nice and simple fix 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #693419 27th May 2024 8:32am
JayGee
I was pleasantly surprised by how easy it was which partially offset the cost. With the benefit of hindsight I’d have just changed the bags. 2012 TDV8 Vogue (L322)
Post #693420 27th May 2024 9:10am
dingg1
You two were lucky, those 2 bottom bolts can be a bit troublesome to say the least, as can one of the ball joints.
Re changing bag, also troublesome to achieve a sealed bag ime...
The price of a full strut is worth it, rather than messing about...
Post #693431 27th May 2024 12:50pm
JayGee
Price of a pair or front struts with variable damping is not at all cheap though. Where did your seals leak when you tried it? 2012 TDV8 Vogue (L322)
Post #693444 27th May 2024 4:44pm
TDV8 Paul
Yes- I must admit I was expecting a fight from these, but they came off first time, I didn’t undo any ball joints luckily 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #693494 28th May 2024 3:28pm
Andyyav
i've ordered the passengers side, fingers crossed its just as easy!!! 1972 Series 3 full of character
1992 90 Exported
2011 L322 4.4 VSE
Post #693500 28th May 2024 4:46pm
