Home > Maintenance & Mods (L322) > 5.0 supercharged oil service - oil low
RRD
Belgium 2012 Range Rover Vogue TDV8 Santorini Black
Hi guys,
Bought a 2010 5.0 S/C few months ago. I wanted to do an oil change today and here's what happened. I checked the oil level on the display and it said "Engine oil too low".
I then took the old oil out of the car and only 4 liters came out, where there's supposed to come out +/- 8 liters Shocked .
Is there no hard fault on the dash when the oil level goes under a certain point? I can hardly believe the engine is only holding 50% of the amount of oil as it should. No weird noises. Engine runs smooth. I'm scared of overfilling it so I don't really know what to do now. Can the oil level sensor be tested? Damn Land Rover for not putting a physical dip stick on these engines!!
What would you guys do? '17 Range Rover 5.0 Supercharged AB (Sold)
'16 Range Rover SDv8 AB (Sold)
'15 Range Rover SDv8 Vogue (Sold)
'13 Range Rover SDv8 Vogue (Sold)
'12 Range Rover TDv8 (Sold)
'10 Range Rover 5.0 Supercharged
'03 BMW E39 M5
'01 BMW E46 M3
Post #693187 23rd May 2024 3:05pm
The engines are designed to supply oil at some silly angles when off roading, they always carry much more oil than they need in normal driving, it should be fine, just replace with the correct amount but don't overfill it.
There might be a low oil warning but a lot are not turned on at the PDI, you can check with an IID or similar... Thumbs Up Pete
Post #693188 23rd May 2024 3:23pm
JayGee
If the oil was too low it would cause a low oil pressure warning on braking, accelerating or cornering. Unlikley this would be turned off in the PID even if for some inexplicable reason the oil level warning was. 2012 TDV8 Vogue (L322)
Post #693191 23rd May 2024 3:34pm
RRD
Ended up filling it with 7.5 liters of 5w20 to get it to the correct level. I called my local Land Rover mechanic and he confirmed that there's no hard fault on the dash with these cars for low oil level.
"You'll end up getting a low oil pressure warning and then you're probably too late" Shocked .
Anyway, lesson learned. I think I got really lucky here that I didn't break the engine. According to the service book the last oil service was 15k km ago, but I don't know if the mechanic filled it up with the right amount or just put back in what he got out of it... Will be monitoring oil level now. '17 Range Rover 5.0 Supercharged AB (Sold)
'03 BMW E39 M5
'01 BMW E46 M3
Post #693247 24th May 2024 12:48pm
JayGee
I guess if you parked on a slope you don't want low oil level warnings 2012 TDV8 Vogue (L322)
Post #693251 24th May 2024 2:30pm
dhallworth
On the 5.0 engine there is no oil pressure switch so you won't get a low oil pressure warning Sad
I found this hard to believe but having been all over mine whilst repairing it, and having read online, it does in fact seem to be true. Shocked
Post #693308 25th May 2024 8:38pm
JayGee
Shocked 2012 TDV8 Vogue (L322)
Post #693325 25th May 2024 10:56pm
