![]() | Home > Maintenance & Mods (L322) > 5.0 supercharged oil service - oil low |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8436 ![]() ![]() ![]() |
The engines are designed to supply oil at some silly angles when off roading, they always carry much more oil than they need in normal driving, it should be fine, just replace with the correct amount but don't overfill it.
If the oil was too low it would cause a low oil pressure warning on braking, accelerating or cornering. Unlikley this would be turned off in the PID even if for some inexplicable reason the oil level warning was. 2012 TDV8 Vogue (L322) |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
Ended up filling it with 7.5 liters of 5w20 to get it to the correct level. I called my local Land Rover mechanic and he confirmed that there's no hard fault on the dash with these cars for low oil level.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3162 ![]() ![]() ![]() |
On the 5.0 engine there is no oil pressure switch so you won't get a low oil pressure warning |
