Home > Maintenance & Mods (L322) > C1 or C3 Oil on a L322 2011 TDV8?
JayGee
Sulphated Ash is the value. Not sure companies do recommend oil that is not to spec as if you put in the exact vehicle into both Castrol and liquid Moly sites it comes back with the right oil. The owners manual is also very clear so not sure why selecting the correct oil is difficult or complicated. BTW fuel adatives won’t remove ash from the DPF. 2012 TDV8 Vogue (L322)
Post #692920 18th May 2024 9:10pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Hey Jaydee
So after checking the tool shed I realised when I researched this before I actually used a different spec oil compared to what the site recommended for the 4.4TDV8 2010-2012
So on the Liqui Moly product I used Top Tec 4500 5W-30 which is specific to Acea C1, Jag/Land Rover STJLR.03.05 and Ford WSS-M2C 934-B
https://www.liqui-moly.com/en/ie/top-tec-4...ions-title
I knew it would be like to me to use what the website said!! Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #693014 20th May 2024 8:17am
JayGee
Thumbs Up 2012 TDV8 Vogue (L322)
Post #693017 20th May 2024 9:30am
