![]() | Home > Maintenance & Mods (L322) > Rear wash wipe mod. |
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 76 ![]() ![]() ![]() |
My rear washer works, but only one jet and it takes ages for water to appear. Which then continues even after I release the lever.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
I replaced the non return valve on mine with a cheap EBay item some time ago , so it was easy to extend the tube by simply removing the short tube into the wiper motor and using the valve as a back to back connector..
Craig,
I have added a 90* back to back at the point it goes through the grommet since I took this photo to stop the tube getting kinked when the spoiler is tightened down.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
i have done this mod and put a hole through the spoiler |
The 90 elbow solved the pipe kinking problem and all eight jets fire water directly on to the glass at full force pressure much better than the original setup without the need to make any new hole.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
Lovely mod - I have the same issue after rebuilding my rear washer motor and I'm not paying £180(c) for a secondhand unit to have the same issue.... |
Peter_S Member Since: 28 Feb 2025 Location: Derbyshire Posts: 2 ![]() ![]() ![]() |
Following the advice on here I stripped and rebuilt the motor and gave one of those a go. Works pretty well, good flow of water across the screen. Easy to fit (I'm no mechanic) and my new to me RR has a clean rear screen for the first time in years I suspect!
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
Mine arrived this morning, so hoping to fit over Easter Weekend |
