Home > Maintenance & Mods (L322) > Rear wash wipe mod.
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
My rear washer works, but only one jet and it takes ages for water to appear. Which then continues even after I release the lever.
I'm thinking it must be the non return valve.
Anyway, I found this on ebay and was thinking of trying it:
https://www.ebay.co.uk/itm/255955007977
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #686863 1st Mar 2024 8:31am
Baltic Blue
I replaced the non return valve on mine with a cheap EBay item some time ago , so it was easy to extend the tube by simply removing the short tube into the wiper motor and using the valve as a back to back connector..
Post #686864 1st Mar 2024 8:56am
Baltic Blue
Craig,
I might be tempted to do away with the cable ties when the weather improves, but I have in mind stripping it all and securing the tubing to the wiper arm by threading them both through some black rubber shrinkdown tubing.
Mike Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #686892 1st Mar 2024 1:24pm
stevehathway2024
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Have you any more pics please of the way you routed the pipe through tailgate please. I'm doing the mod now . Thanks Steve
Post #692731 15th May 2024 5:06pm
Baltic Blue
I have added a 90* back to back at the point it goes through the grommet since I took this photo to stop the tube getting kinked when the spoiler is tightened down.
Post #692732 15th May 2024 5:47pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
i have done this mod and put a hole through the spoiler Thumbs Up no kinks in pipe that way
Post #692816 16th May 2024 8:41pm
Baltic Blue
The 90 elbow solved the pipe kinking problem and all eight jets fire water directly on to the glass at full force pressure much better than the original setup without the need to make any new hole.
Post #692819 16th May 2024 9:00pm
Superspoons
Lovely mod - I have the same issue after rebuilding my rear washer motor and I'm not paying £180(c) for a secondhand unit to have the same issue.... Sad
Parts ordered - nice little weekend job coming up.... Thanks again. Thumbs Up Gavin
https://www.youtube.com/@ChallengingClassics
Post #692848 17th May 2024 10:42am
