Home > Technical (L322) > L322 4.4TDV8 Westminster Top End Oil Leak |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3121 |
The brake cleaner will just wash the oil off and it will drip down under the car so just make provision for that. No need to wash it off as it will evpourate so don't do it in an enclosed space. Never liked steam cleaning in engine bays as the water gets into the electical connectors. 2012 TDV8 Vogue (L322) |
15th May 2024 1:38pm |
kernokerno Member Since: 12 May 2024 Location: cornwall Posts: 12 |
Thanks for your help JayGee will update how i get on |
15th May 2024 3:03pm |
Ok just an update
3rd Jun 2024 11:22am |
3rd Jun 2024 11:41am |
27th Jun 2024 12:44pm |
Ok managed to find part
27th Jun 2024 1:06pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 320 |
I would do an oil/filter change anyway. I used a pump and it appeared to get most of the oil out.
28th Jun 2024 3:56am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 528 |
Hi, Oil floats on water so assuming the extraction tube goes to the very bottom of the sump it should pull the water out before the oil so you may be safe.
28th Jun 2024 8:56am |
The extraction tube connects to the sump drain plug so it gets as much out as if it had a sump plug. 2012 TDV8 Vogue (L322) |
28th Jun 2024 9:43am |
