Home > General (L460 2022) > 10,000 mile Range Rover L460 review
fisha
On my L405 and 640d, each diesels and an 8 speed box, when they are cold they are both a bit clunky at slow speeds, particularly if you let off the throttle and coast up to something … its like the engine braking is harsh on the change down. It loosens off when things are warmed up though. I just figure it’s a symptom of the engine and gearbox programming when cold and being warmed up. V8 or else ...
Post #692455 12th May 2024 2:46pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I have this with mine but it is a P530.
The throttle map/gearbox map and probably several other ECUs need improving.
Make your dealer investigate and when they say to you it is just a characteristic of the car insist that they feed it back up to JLR. letters not necessarily in the right order
Post #692469 12th May 2024 5:16pm
5.0
I had a harsh change down on my L405 5.0 S/C when slowing to a rest but my p530 is always very smooth.
Post #692479 12th May 2024 7:30pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Great write up, way above my pay grade but nonetheless very interesting.
The car looks superb Thumbs Up Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #692483 12th May 2024 8:41pm
Dixy
Well this is the latest update, will be interesting to see if it cures the woe. letters not necessarily in the right order
Post #692502 13th May 2024 7:48am
Bill
Bill wrote:
As for no buttons… I find menu’s frustrating , but frankly once the car is set up there are very few reasons to go into them again. I only use voice controls on high days and holidays.
Smile
I had a MY24 velar today as a loan car during a service.
Identical everyday controls to th FFRR
No buttons- had to adjust the heating Easy peasy on the screen . No thought required. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #692533 13th May 2024 5:26pm
Freddy Bear
I just re-read the comments on this 10,000 mile review and realised I hadn't replied - apologies for that.
teeleh and Cam-Tech-Craig thanks for the tip regarding using the heated rear screen switch to turn on the heated mirrors! Because of the rear view camera I never use the heated rear screen but thanks to your advice problem solved!
Bazzert9 approach unlocking and walk away locking have now appeared in the settings so like you mine are now working fine. I don't use the walk away locking but really like the approach unlocking.
jez000 yes, we were in Les Gets and Morzine in 2023 - spot on! Did you see the car there? We went to Whistler last year but have just come back from Les Gets again this year. It was an epic trip and all of us aboard agreed there is no better car for the job.
L460owner I experienced something similar to the low speed dragging you described on my previous L405s. It is not entirely absent on my L460 D350 but much better (one assumes due to the MHEV). I tend to nudge the car into sport to enter roundabouts etc which overcomes it.
Hope you are all enjoying your cars!
Fred
Post #713155 2nd Mar 2025 11:58am
