![]() | Home > Maintenance & Mods (L322) > Wiper blades |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 221 ![]() ![]() ![]() |
Bosch 808’s here. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Has anyone figured out how these fit ?
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi, there are a number of threads on this if you search for them, but essentially, remove all the bits of plastic from the wiper arm and then they'll just clip in, you can't fit them until all the plastic is off.
Are you saying that the plastic is still fitted in my second picture ?
Hi, if what you have is the same as mine then it's the wiper arm, you need to remove all the plastic bits, once you do that it should be obvious how the blade fits, see mine below.
Just fitted these to mine. Seem to give a clean even sweep but will withhold proper judgement until I’ve used them in rain and at speed as there is now no ‘spoiler’ on the drivers side. 2012 TDV8 Vogue (L322) |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
I tried them and went back to 808 s as they lifted at speed so for me no good - make sure you dont throw the spoiler away tricky bit to find if you ever change back |
