Home > Maintenance & Mods (L322) > Wiper blades
PeteT80
Bosch 808’s here.
Post #692123 8th May 2024 5:28am
Baltic Blue
Has anyone figured out how these fit ?
Thought I would give them a try, but I am beaten.
Post #692299 10th May 2024 12:15pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, there are a number of threads on this if you search for them, but essentially, remove all the bits of plastic from the wiper arm and then they'll just clip in, you can't fit them until all the plastic is off.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #692304 10th May 2024 12:41pm
Baltic Blue
Are you saying that the plastic is still fitted in my second picture ?
I can’t see how any more bits come off ?
Mike..
PS
It’s just taken me 20 minutes to refit the original because I removed the plastic locking slide. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #692305 10th May 2024 1:16pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Baltic
My only thought is Andy meant take all the plastic off the wiper blade rather than the wiper arm
Your piccie shows what I understand to be the wiper arm and looks like mine - nothing to remove on the wiper arm
Post #692357 11th May 2024 2:09pm
AndyRoo
Hi, if what you have is the same as mine then it's the wiper arm, you need to remove all the plastic bits, once you do that it should be obvious how the blade fits, see mine below.
Andy
Post #692362 11th May 2024 2:28pm
JayGee
Just fitted these to mine. Seem to give a clean even sweep but will withhold proper judgement until I’ve used them in rain and at speed as there is now no ‘spoiler’ on the drivers side. 2012 TDV8 Vogue (L322)
Post #693354 26th May 2024 1:25pm
Sandyt
I tried them and went back to 808 s as they lifted at speed so for me no good - make sure you dont throw the spoiler away tricky bit to find if you ever change back
Post #693414 27th May 2024 7:35am
