Home > Technical (L405) > Global opening/ shutting |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1256 |
You might need to re program the rears for the one touch close function to work properly first as that is the function of the window that the remote will ask the car to do when holding the lock button down.
11th May 2024 12:05am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 702 |
Thank you Fisha
11th May 2024 8:22am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
I don't know whether it always works like this, but as part of the battery replacement procedure, it states - "Reset electric window one-touch facility. Power window up to hard stop, release switch, reapply and hold for 1 second (relay in door will click). One touch should now work" |
11th May 2024 9:10am |
I changed my batteries today - and the one touch was reset (off). I managed to get the rears working but not the fronts. I can confirm at this point that global closing only closed the rears. After a bit of perseverance, I got the fronts working again and global closing now does them all.
11th May 2024 3:00pm |
Many thanks Fisha and Alistair, closed windows and held the button!
11th May 2024 3:59pm |
