![]() | Home > Technical (L322) > Should I be worried? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
Here's what I found when I did mine:
I only replaced the gaskets & o-rings, and after 30 months and 25k miles, there's not been any issues or oil loss at all. There does seem to be quite a bit of recent scratching in there - noticeable on yours that it's over the gasket marks meaning it's not from original production. However, the latest gaskets are larger (beefier) than the originals, so they might do the job there. That said, I'd be seeking another opinion from someone more knowledgeable than me! ![]() ![]() |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
I think someone has at least tried to clean the surface but used too course a paper. I would block all the passage ways with kitchen towel and use a finer grade abrasive on a flat backing block. |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 166 ![]() ![]() ![]() |
With the fear of making it worse I did nothing….
