![]() | Home > Technical (L405) > How many Locking Diffs do you have? |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
Not from the factory. |
BoostCrzy Member Since: 05 Jul 2021 Location: Sheffield Posts: 1 ![]() ![]() ![]() |
Hi
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
(Duplicated Post) |
My 2013 4.4 SDV8 AB had a rear locker, but my current car (2014 5.5 SC) doesn't ... |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 90 ![]() ![]() ![]() |
I tried to discover the same information while looking for an L405. I think the real answer is "there is no single answer". Whether it's not available, an option, or standard, seems to vary by trim level, engine, age and market. I never found an easy way to determine if the car has a rear locker. |
Leon Member Since: 24 Apr 2024 Location: Wellington, New Zealand Posts: 4 ![]() ![]() ![]() |
I would say the only way to confirm is to climb underneath and check for the engaging motor on top of the rear diff.
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 44 ![]() ![]() ![]() |
I may be wrong but if you look at the build sheet for a prospective car, then it is shown (well it is on mine).
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
I specced it on my P400e and I noted from the specific screen that the computer uses it a lot of the time, especially in the wet. I don’t use mine offroad but I imagine it would be game changer for that use case given my experience with regular lockers. I don’t know how much they weigh, but assuming negligible then the active centre diff lock is a no-brainer in all cases. It’s certainly useful in putting down a lot of torque, for which the SDV8 is a perfect example. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1405 ![]() ![]() |
My SDV8 Auto has an open diff on the rear.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 453 ![]() ![]() ![]() |
quick question when you select the 4 wheel drive option and you see the diff locking up do you feel it (snagging best way to describe it) and do you get any noise when it engages ? |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1035 ![]() ![]() ![]() |
Short answer; no. BTW, you can’t select 4WD in a FFRR, it has permanent 4WD. There are a variety of selectable terrain options, which is perhaps what you mean? |
