Home > General > Late L322 or early L405 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2761 |
Used L405 prices have certainly dropped significantly since I last looked. £25k gets you something very nice if you can afford the £10k a year insurance I'd have to pay here in London...... 2012 TDV8 Vogue (L322) |
25th Apr 2024 1:08pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2987 |
The corrosion on the L405 is worse in some ways! On the L322's it's the cills that corrode and they can be repaired fairly easily. On the L405 it's the aluminium body that corrodes due to it having a steel subframe bolted to it and the corrosion can be much worse and I'd imagine an awful lot more difficult to repair. See the first post in this thread: https://www.fullfatrr.com/forum/topic61477.html David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2007 Range Rover Supercharged in Java Black with Ivory Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior |
25th Apr 2024 6:44pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
I won't reveal how much I paid 2015 Range Rover Autobiography 4.4 SDV8 |
25th Apr 2024 6:57pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 379 |
Thanks David, that's an interesting thread, and frankly quite shocking. You would think there would be an non-conductive isolator gasket between the two dissimilar metals to prevent such bimetallic corrosion. A simple rubber / plastic gasket between the two components would solve the issue! I checked the parts diagrams and couldn't see anything. LR037508 looked like a candidate, but it's actually painted steel from the looks of it, and the oval parts you can see on top of the subframe mounts on the thread you originally linked. Having said the above, I do wonder if that vehicle has been in a salt water flood, or spent time launching boats? The ARC pipes and fuel tank guard show quite a bit of surface corrosion. Anyone know how long the L405 anti-corrosion warranty is? Audi for example have a 12 year corrosion warranty on their aluminium bodies. All I could find with a quick Google search was 6 years from LR... pathetic frankly. 1992 RR Classic 3.9 efi Vogue =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
25th Apr 2024 11:13pm |
sjn Member Since: 11 Apr 2024 Location: Birmingham Posts: 14 |
I've just bought myself a late L322 4.4TDV8 with 50,000 miles and I couldn't be happier ....to me the L322 is the last real range Rover.
28th Apr 2024 1:17am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 204 |
I was in this same predicament when replacing my 07 VSE tdv8.
1st May 2024 9:59am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 387 |
Just looking around on Autotrader I can see that there are increasing numbers of 2013 4.4 SDV8 405s for less money than their equivalent 2012 L322 models.
1st May 2024 12:05pm |
107SW Member Since: 03 Jan 2016 Location: Bucks Posts: 26 |
Interesting comments from experienced owners here, thank you.
7th May 2024 4:21pm |
Should also comment that I have now heard of insurance becoming a little more sensible - let's hope so! |
7th May 2024 4:22pm |
Nope!!!! I’ve just had my renewal through- it’s doubled and it’s pretty much the same wherever I go!!
8th May 2024 7:33am |
