Home > Maintenance & Mods (L322) > Gloss D Pillar Trim
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Gloss D Pillar Trim
Hi,
I saw a white SC AB L322 advertised in Autotrader and noticed it had gloss finish D pillar trim. Is this something commercially available or something the owner may have had done ?
I like the idea of gloss black A & D pillars, but I have no idea where to source them.
I've trimmed the picture as I don't want to infringe copyright but you get the idea.
Seen these around anywhere ?
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #691766 2nd May 2024 4:25pm
johnboyairey
I had an older 2002 l322 in bright silver with silver A and D panels. when I looked on the build, it was a specced factory option.
Post #691769 2nd May 2024 4:50pm
AndyRoo
OK, thanks for that, I'll see if I can source some. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #691789 2nd May 2024 8:06pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
No quite gloss but the product below brings plastics back to factory spec for over 6 months in sun so as I say not quite gloss but very new looking. I use on the disco plastic and I have a new bottle for the Westie just havent had a chance to apply it yet. I actually used it on a cordless phone yesterday and it made it look like new.
If I apply over the weekend Ill do a before and after
https://www.gtechniq.co.uk/shop/auto/wheel...-restorer/ Current yokes
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #691810 3rd May 2024 9:22am
AndyRoo
I think I'll get one off scambay to play with before I commit to do anything on the car itself as it's not just a mat finish it's actually quite rough so I'll need to sand back.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #691814 3rd May 2024 10:22am
kevinp
I ended up colour coding my pillar covers, Santorini black, because they always looked a bit 'tatty' and am pleased with the result. Can you do the same?
Post #691816 3rd May 2024 11:08am
AndyRoo
Mine's white so I was really going to extend the floating roof theme by glossing the A & D pillars as the glass is gloss as I have tints so it'll be like a gloss black band around a white car.
It works in my minds eye, but who knows, I've ordered a D pillar trim, so I'll try that first and see how it turns out before I commit to doing it on the car itself.
Post #691818 3rd May 2024 11:43am
kevinp
If you do paint one make sure you use a good barrier coat first. Mine started to wrinkle hours after applying the paint and had to start all over again. Thumbs Up
Post #691819 3rd May 2024 1:37pm
AndyRoo
Yes, that's my worry, hence getting a used test panel. I'll need to do all the door frames as well as they're satin black at the moment. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #691820 3rd May 2024 1:40pm
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Did you paint them whilst in situ? Removing the trims is easy but you need a supply of replacement clips in hand as some will always break. Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs
Post #691834 3rd May 2024 4:19pm
kevinp
I took them off to paint. Thumbs Up
Post #691845 3rd May 2024 7:13pm
RogueRanger
And did you manage not to break any clips? Des
Post #691858 4th May 2024 1:43am
kevinp
Of course not. Rolling with laughter
You also need to source the fasteners for inside the door and tailgate reveals.
Post #691860 4th May 2024 5:58am
RogueRanger
Well done on a fine job, fellow mortal! Des
Post #691930 4th May 2024 11:32pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Powerful UK do a video on how to remove the D panels and you have to punch the clips through into the panel and the replace with new. I was thinking of doing mine, but you would also have to do the A pillars & then the B pillars would look odd if not also done & then the wing mirror arms would need doing & so on. Where do you finally stop?
So I'm sitting on the fence at the moment with this one. If anyone has part tacked the job and has phots to share, that would be welcome..... 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #691957 5th May 2024 12:55pm
