![]() | Home > Technical (L405) > Possible Turbo issues |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi folks,
Further to the above, I have collected the car as the part wasn't immediatly available and they have other bookings - its booked back in for 10 days time.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1458 ![]() ![]() ![]() |
Afternoon comports,
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
It's a 1 hour job. The valve is just above the exhaust.
Thanks all,
Thanks all for the advice - I don;t have access to Topix but did phone LR to ask them the service time for fitting the shut off valve..
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 472 ![]() ![]() ![]() |
Check you don’t have a vacuum leak, there are lots of small pipes connecting between the valve you describe and the vacuum pump located on the front N/S of the engine. There is also a pipe going from the O/S air filter box to the valve block that will cause issues if leaking or disconnected.
I would totally expect to still have to pay, because at the end of the day, they have done the work, and engines are complex things - it's not necessarily straightforward to diagnose.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1306 ![]() ![]() |
Did you check the trash bag? aka its LR Time 2018 SE SDV8 4.4 Byron Blue |
Thanks garyRR
I'm done... I emailed the garage with a concern that even LR Topix suggests the job to replace the shut off valve... their response...
Afternoon all,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1290 ![]() ![]() ![]() |
Has the COSV been checked that it is not seized? I presume it's the same valve and location on the 405 as the L322. |
Thanks Kevin
