![]() | Home > Maintenance & Mods (L405) > Oil Cooler Change - Miles to Service question |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I reset mine after each oil and filter change even though I only do a full service, air and pollen and fuel filters every 2nd year, because it resets the oil/ fuel dilution calculation figure, for the new oil to zero.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 215 ![]() ![]() ![]() |
I was a little surprised that they didn't reset as I had intended to when I was about to change the oil myself but didn't bother as it was going in for the oil cooler replacement. Not sure whether I should reset it myself now or just leave it as is until it's annual service in November. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1155 ![]() ![]() ![]() |
it should be reset! do it yourself its easy. overfinch modified |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3871 ![]() ![]() ![]() |
I just did an oil change (6months) and just reset mine. Have it done every 12 months at Indy and they do MOT as well. They also reset to service indicator, I think oil condition is probably the most important thing on a service so why not reset it. Geoff |
So what would be the best way to reset miles to next service after changing the oil then? I have just tried to do it with an iCarSoft LR v3 and it wouldn't do it, error was 'failed to communicate'? Is there a better way to do it? _______________________________________________
I think it's pretty well documented I did something that involved opening the bonnet, cycling the ignition, opening the drivers door and pressing both pedals, seemed to work with no gadgets involved. Geoff |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Reset it. Oil dilution calculations have to be reset. They should know that.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1268 ![]() ![]() |
Service reset 2018 SE SDV8 4.4 Byron Blue |
Well done Kot, I think I used this video- simples- no need to bother with IDTool or iCarSoftLRv3 (whatever that is) Geoff |
Cheers Kot, followed the video, worked perfectly and mileage reset. I still dont understand why they did not reset when they knowingly had to change the oil but hey-ho, it is so easy to do now that I know I can do it myself. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Changing the oil is only a small aspect of a service... There are many safety checks carried out at time of service and if the rest of the service and vital service checks were not carried out? Why would you expect a garage to reset the annual service light? Doesn't make sense to me sir...
If (as I always do) change the oil more often than required I do a reset if for nothing else that to turn of the annoying warning every time I start the car. I get the car serviced and MOTd annually anyway.
I understand the garages point of view and it makes perfect sense and I am indeed only thinking about the oil dilution potential. I have an annual service regardless of mileage so that covers pretty much everything else. I was only really curious as I will be doing my own oil change between services and just wanted to know if there was any particular reason why I wouldn't reset the mileage indicator then? _______________________________________________
