Home > Technical (L322) > L322 In Tank Fuel Pump or Sender Wiring Failure
Fiorano575
United Kingdom 2012 Range Rover Vogue SE TDV8 Java Black
Hi
L322 4.4 TDV8 2011
Anyone know what the part number is for the in tank fuel pump?
A diagram would help and maybe an idea of what's involved to change it?
The one that breaks you down when you have a quarter tank of fuel Smile
Thanks Guys!
Post #691763 2nd May 2024 2:52pm
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Is it the pump or just a faulty gauge wiring?
If you search the forum, there are several examples of members who repaired the wiring themselves.
I got my local Indy to repair my wiring, it cost less than £200. -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #691772 2nd May 2024 3:53pm
Fiorano575
That's a great question and I'm not sure. I broke down several months ago and recovered the car to a RR specialist. Since then I have made sure my tank is always half full.
It may well be the wiring but I'm not really sure.
Post #691773 2nd May 2024 4:00pm
Fiorano575
I checked the search but couldn't find any info on this issue.
Post #691775 2nd May 2024 4:07pm
Giffer2018
Try these links,
https://www.fullfatrr.com/forum/topic46574...p;start=15
https://www.fullfatrr.com/forum/topic41061...gage+guage
https://static.nhtsa.gov/odi/tsbs/2014/SB-10102562-9340.pdf
Hope they help. -----------------------
Post #691777 2nd May 2024 4:15pm
Fiorano575
Thanks a bunch for those links! Thumbs Up
Post #691778 2nd May 2024 4:27pm
AlexLRV8
United Kingdom 2008 Range Rover Vogue TDV8 Zambezi Silver
There is a service bulletin about this somewhere. I had the same problem. It's caused by a faulty connector in the tank. I pulled the main pump, jet pump and senders out of the tank and cut off 2 or 3 connectors and soldered the wires together. Less than an hour and effectively a free fix.
Post #692032 6th May 2024 9:46pm
rjff
Service bulletin
TECHNICAL BULLETIN
LTB00566NAS4
10 OCT 2014
A quick search online with that brings it up. OR
https://www.tsbsearch.com/Land-Rover/LTB00566NAS4 Cheers
Richard
Gap IIDBT
Post #692044 7th May 2024 6:26am
Fiorano575
Thanks for that. I thought it was an issue with the in tank pump failing?
Is this wiring issue the real cause of fuel starvation when there is a quarter tank or so of fuel?
Post #692092 7th May 2024 4:15pm
AlexLRV8
Yes.
The tank is saddle shaped to give space for the propshaft. So on one side you have the main pump that delivers fuel to the engine and on the other side is a small pump that transfers the fuel over to the main pump side. The wiring connectors which dont even need to be there become loose over time being wiggled by the fuel sloshing around in the tank.
The reason your gauge still reads about a quarter tank when you run out of fuel is because there are two senders, one either side of the tank. The car takes an average of both and displays that on the gauge. So one empty, one half = quarter tank on the gauge.
So the main pump is running dry because the small pump isn't working. So that's either a failed jet pump or faulty wiring/connectors. I've never heard of the small (jet) pump fail and there's a bulletin for bad connectors so that's my bet.
You need to see that service bulletin, it's got pictures of the connectors to remove. Also, look up how to remove the pumps from the tank as you could break the mechanism that holds them in place if you're not careful.
To add, that service bulletin I seem to remember was for '10-'12 but mine is an 08 and I know of other earlier cars that had this problem too.
Post #692121 7th May 2024 11:40pm
