Home > Technical (L322) > L322 Tow bar Wiring
beulahgigFFRR
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
L322 Tow bar Wiring
Hi, i fitted a Westfalia towbar as it was without a tow function. Wiring came with it but without fitting instructions. However, it appeared fairly straight forward. The mechanical side is good https://www.fullfatrr.com/forum/images/smiles/icon_smile.gif,
the electrics should just be plug and play and it has the siemens ECU, plus the 8 pin connector that hooks into the receiver of the car, but cannot get it to work https://www.fullfatrr.com/forum/images/smiles/icon_sad.gif
It is the 13 pin version. Any thoughts or advice is much appreciated.
Post #691545 29th Apr 2024 3:12pm
winco
I should imagine the wiring kit would need to be coded to the car using a software tool such as SDD or GAP IID. 2010 5.0 SC Autobiography Overfinch in Bentley Silk White pearlescent, 22" Overfinch wheels with 285/35x22 tyres
Post #691605 30th Apr 2024 2:19pm
beulahgigFFRR
thank you.
Post #691606 30th Apr 2024 2:36pm
