Home > Maintenance & Mods (L322) > O-rings in coolant hoses
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I've just fixed the 94th coolant leak on my 4.4 SDV8 (2014), all caused by o-rings in the coolant hoses going 'flat'.
See pic below. This one was cheap - the vent hose from radiator top to expansion bottoe.
Is it just me?
It seems that I will have to spend the rest of my ownership changing o-rings one by one if the last 2 years is anything to go by...
Chris.
 L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #691167 23rd Apr 2024 5:30pm
garyRR
So, my question is, how are you identifying the leaks? I'd love to be able to even identify 1.
These engine bays run so warm that it can often evaporate before you see it. 2015 Range Rover Autobiography 4.4 SDV8
Post #691177 23rd Apr 2024 9:26pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
I found that the red coolant in my 3.6 leaves red traces when dried up. One of them endoscope camera things for your phone might help.
Post #691181 24th Apr 2024 3:53am
ChrisJC
Easy - it has a very characteristic smell. I can smell it just walking past the front of the vehicle.
So I keep my eye on the coolant and when it starts to go down faster I have to start investigating properly to find the leak.
Always an o-ring.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Post #691182 24th Apr 2024 6:29am
garyRR
Are you able to see the leaks, or do you use a pressure tester or UV dye or anything? 2015 Range Rover Autobiography 4.4 SDV8
Post #691185 24th Apr 2024 7:31am
ChrisJC
It's bright pink anyway, so fairly easy to spot. The problem is usually the sheer amount of 'stuff' in the way, so an endoscope (USB camera), torch, and maybe removing some of the stuff is required just to confirm the leak is where you think it is.
P38 - 4.6V8 HSE
Post #691195 24th Apr 2024 11:20am
